Feb 7, 2016 #1 L LSTTYPE Active Member Joined Dec 31, 2001 Messages 739 I have a nice set of TTA valve covers freshly bead blasted that I will take 100$ plus shipping for. P.M or text 785 806 2331 if interested ,thanks Attachments image.jpg 1.4 MB · Views: 64
Feb 7, 2016 #2 L LSTTYPE Active Member Joined Dec 31, 2001 Messages 739 More pics Attachments image.jpg 1.7 MB · Views: 38 image.jpg 1.8 MB · Views: 25 image.jpg 1.6 MB · Views: 25
Feb 9, 2016 #3 G gteatr6 Member Joined Apr 10, 2004 Messages 557 LSTTYPE said: More pics Click to expand... Pm sent
Feb 9, 2016 #4 Pronto No amount of evidence will ever persuade an idiot. Joined Dec 9, 2002 Messages 16,822 Are these still available and do you have the hardware to mount them?
Feb 9, 2016 #5 F fbody4me Member Joined Aug 18, 2007 Messages 32 FYI... The drivers side(oil fill) valve cover is not the correct one for the TTA.
Feb 9, 2016 #6 L LSTTYPE Active Member Joined Dec 31, 2001 Messages 739 What is different on the drivers side that makes it incorrect? I can weld up the hole in the front if that's the issue. These did come off a fwd lesabre I thought they were the exact same.
Feb 9, 2016 #7 L LSTTYPE Active Member Joined Dec 31, 2001 Messages 739 When I google TTA valve covers, it shows a hole in the front of the valve cover.
Feb 9, 2016 #8 F fbody4me Member Joined Aug 18, 2007 Messages 32 Yes its the hole at the end. The hole on a TTA is on the long side by the oil fill hole.
Feb 9, 2016 #9 L LSTTYPE Active Member Joined Dec 31, 2001 Messages 739 Do most people plug the side hole? I can weld, grind and then bead blast the hole at the end if someone wants them.
Feb 9, 2016 #10 V V8Killer GM speed junkie Joined Nov 22, 2001 Messages 329 I'm interested. Do you have the hold down acorn nuts and washers?
