TTA valve covers
LSTTYPE
I have a nice set of TTA valve covers freshly bead blasted that I will take 100$ plus shipping for. P.M or text 785 806 2331 if interested ,thanks
More pics
Are these still available and do you have the hardware to mount them?
FYI... The drivers side(oil fill) valve cover is not the correct one for the TTA.
What is different on the drivers side that makes it incorrect? I can weld up the hole in the front if that's the issue. These did come off a fwd lesabre I thought they were the exact same.
When I google TTA valve covers, it shows a hole in the front of the valve cover.
Yes its the hole at the end. The hole on a TTA is on the long side by the oil fill hole.
Do most people plug the side hole? I can weld, grind and then bead blast the hole at the end if someone wants them.
