Details of the run:
R/T:1.811 (fell asleep)
60':2.018
330':5.559
1/8:8.452
mph:85.68
1000:10.915
1/4:12.973
mph:111.45
1badTTA, TTA#332
EMPTY WEIGHT: Never weighed
BLOCK:109
HEADS:Stock
TRANSMISSION:Stock
TORQUE CONVERTER:Orange Stripe, 2750 stall @5psi, Locked in 3rd
DIFFERENTIAL:Stock
INTERCOOLER:Stock
THROTTLE BODY:Stock
RJC POWER PLATE:Yes
INJECTORS:Stock
THERMOSTAT:160
TURBOCHARGER:Stock
VALVE SPRINGS
ostons 110psi
MAF:Stock 1 screen removed
DOWN PIPE:Stock
EXHAUST:Stock Test pipe and ATR Pitbull muffler
FUEL PUMP:Walbro 340 Hotwired
FUEL PRESSURE REGULATOR:Bittel top adjustable
FUEL PRESSURE:43psi?
ALCHOHOL INJECTION:no
PROPAIN INJECTION:not then
NITROUS:never
AIR FILTER AND AIR INTAKE:K&N cone
TIRE DESIGN, SIZE & AIR PRESSURE:BGF Radial TA (not DR's)@20psi
AIR BAG(s):no
SCAN TOOL
irect Scan
FUEL:5 gallons 110 in empty tank (about 1-2 gallons 91 remaining?)
CHIP:MM 8 position
CHIP TIMING:24*
KNOCK RETARD:0
OXYGEN SENSOR VOLTAGE:.780
EXHAUST GAS TEMPERATURE:N/A
TRACK ELEVATION:3075ft
TEMPERATURE:167 (thats what the timeslip says) probably high 80's
PEAK BOOST:18psi
BOOST AT LAUNCH:5psi
MILES ON THE CAR/ENGINE:49,xxx
60':2.018
330':5.559
1/8:8.452
mph:85.68
1000:10.915
1/4:12.973
mph:111.45
1badTTA, TTA#332
BLOCK:109
HEADS:Stock
TRANSMISSION:Stock
DIFFERENTIAL:Stock
INTERCOOLER:Stock
THROTTLE BODY:Stock
RJC POWER PLATE:Yes
INJECTORS:Stock
THERMOSTAT:160
TURBOCHARGER:Stock
VALVE SPRINGS
DOWN PIPE:Stock
NITROUS:never
AIR BAG(s):no
SCAN TOOL
CHIP:MM 8 position
CHIP TIMING:24*
KNOCK RETARD:0
PEAK BOOST:18psi
