TTop rubber seal
carguy
How do you remove ttop rubber seal without damaging it? Is there a book i can buy that will show me? Are they glue in?
ttop seals
Yeah i tried pulling mines out and they ripped, i am glad was replacing them! Which ones does everybody use for replacement?
The GM ones are the only ones that fit right, but beware. The passenger side I got from GM didn't fit right, and you could tell it wasn't made by the same company that made the driver's side. I ordered another passenger side, and it was right. It was like an aftermarket seal in a GM box.
T-top seals
Main T-top body seals are discontinued from GM.
We carry a pretty good set & have sold over 50 sets to date. No complaints.
We will start seperating the main body seals from this kit & offer the remaining GM parts with these replacement t-top main body seals.
GBodyParts.com Online
Does anyone know where you can get the double sticky tape that holds the weatherstrip channels to the body?I'm gonna peel mine off to clean out the channel and to make sure theres no rust hiding under them.It looks like standard tape but is thinner than the 3m white tape readily available.
Strip Caulk
Years Ago, I Did Warranty Work On These T-roofs. A Gm Rep Suggested We Use 3m (spaghetti) Strip Caulk Under T Bar And Upper W-strip Rails.we Did Not Use Any Type Of Double Back Tape As Water May Leak Past A Seam Where The Tape Meets. Hope This Helps.
Removal Of W-strips
Bob, I Would Like To See How Much Glue Was Used When The W-strips Were Installed, Hard To Tell,but You May Get Lucky,i'll Also Show You The Proceedure Of Installing (or Reinstalling) The W-strips..if I Recall,you Said W-strips Were Recently Replaced Prior To You Purchasing The Car.
