Got a powerloger hooked up and looking for an expert to review as I am having some knock. Testing is mostly in 3rd as this is more a true knock indicator from what I have read.
Mods: 3.5" MAF with translator, TT chip for 93 oct, FMIC, 3:" DP and test pipe, 60 LB inj, DW300 w hot wire, power plate, cold air intake. New radiator and dual fans, stock turbo, poly mounts for the engine and tranny, home ported heads with larger valves, 208/208 flat tappet cam, heavier valve springs.
Known issues: A lot of false knock when trying to do burn out on the street. I did found that the bushings for the stock UCA and LCA are totally shot to the point when the car is in park and you push the car forward and back it makes loud noises and you can visually see the slop in the bushings. Whenever I shift the into D it sets off the knock detector. Worse when its cold but this issue has progressively gotten worse. You can hear a loud click noise when shifting that must be the correct freq to set it off. There is also a 1-2 delayed shift that I need to lift up on the gas super quick and it will go in. If I bring it up slowly it will shift at 3K.
Going after the control arms next so hopefully it will fix some of the lower knock but I am starting to wonder if my tranny is the real knock source. Engine runs great otherwise, no idle issues or backfire when rev d .
