Joe DiMura
87gnvette69
- Nov 19, 2012
so the car has the following; 42# injectors, walbro 305 hot wired, port matched heads/intake, 3" DP, 212/212 ft cam, 30 over, stock IC w/dutt, stock throttle body, rjc spacer, ls1 maf, translator plus gen2, scan master, extender extreme g chip, WB o2, 15# boost, precision 5862 turbo, initial timing set at 16*, fp set at 43# line off (PS i wish i knew how to put this info into my profile!!!)
so car is running great for the most part cruise blm around 123, off throttle drops to 119 and idles blm is 135, but when i start squeezing into the throttle building boost i always get b/t 1 & 2.5 kr and around 14.5 a/f at b/t 57-65 mph. I have added hi a/f from 3400rpm (18%) to 5800 rpm (30%) with very little luck. All other parameters have not been touched.
clearly i no expert at this and i would really appreciate any advice i can get. Thanks in advace.
