Tuning my SMC kit
t-topflyer
Had a surging issue because of interference between the MAF translator and alky controller. Thanks to advice from other members on this board I was able to quickly get the issue fixed by purchasing a hotwire for the translator from alkycontrol. Now that I have it functioning, I would like to dial it in and make everything work at it's maximum potential.
Here are the main modifications to the 87 Turbo Regal:
LT1 MAF with translator and hotwire, 160 t-stat, SMC alky kit, Houston 3" Downpipe with Magnaflow Dual Exhaust, stock turbo and injectors, Billet adjustable fuel pressure regulator, Walbro 340 w/hotwire, K&N 9" cone filter, powerlogger, turbotweak 91 octane street chip timing at 20/18 for 1-2/3-4
Here are a few questions I have:
1. So I don't waste unnecessary amounts of denatured alcohol, what boost I should have the alky spray come on and what boost I should have it at max spray?
2. What should I set max boost at for a stock turbo & injectors?
3. Do I need to mess with the timing?
4. Any other parameters that I should consider adjusting?
Thanks in advance
What is your timing set to now? What boost can you run without the alky kit?
I would start it at 12-13psi, and crank it wide open. Maybe not the most experimental way of doing it, but you will end up there anyway once you get used to lotsa boost..:cool:
Turn the boost up to the point that it starts knocking a tiny bit in 3rd gear. Now back off the boost 1psi or so, and away you go. If you are getting no transitional knock (from a roll or in the lower gears) you can try upping the timing a little bit. If you are playing with timing, make sure you watch the knock, and or lower the boost a little just in case. I ended up having my SMC turn on around 15psi, and the knob turned to 10. Running 27 deg 1/2 and 25 3rd/4th.
