ryanclem74
- Mar 27, 2005
Whats the best way to tune a 1985 gn without converting to a 1987 ecm?
SignUp Now!easy as pie. just add the wires for the IAT and run the wire into the engine bay.Well its not that difficult to make the conversion, am I right? Why not just switch over?
IAT data can be helpful thoOne option is to get an 87 TT chip which ignores the IAT sensor. One less thing to fool with. Brad
I know I am going to sound like a giant noob asking this. But aren't the coilpacks the same??
If your car has no issues, you should be able to follow the advice from Brad.
Not much else you can do besides another TT Chip and playing with the FP.
There are also a few things to look for such as MAF idle/WOT, O2 WOT, and KR readings. This can be done with an OTC monitor (2000 or 4000), or turbolink through the ALDL. It is slow, but, I have seen cars run 110MPH with the OTC2000.
If you are having problems and/or made changes to the OEM set-up, it get a bit more complex and you will need data to review.
The swap can be done for around $170. (ECM and TT Chip)
Sure, some lucky people can find an ECM for $40, but I have not yet succeeded.![]()
