Apr 17, 2010 #1 M maxcom Member Joined Jun 7, 2008 Messages 363 what size bolts do i need for a stock turbo with a THDP ?
Apr 30, 2010 #2 C coach Guest Hey Tom, I believe M8x 1.25x 30 will work just fine. Let a few others confirm this, but it is what I used today on my 49. Take care Donnie
May 2, 2010 #4 W whitehot1 Well-Known Member Joined Oct 24, 2006 Messages 4,682 I have found that studs work better for fastening the down pipe to the turbo. Much less chance of breaking bolts off in the turbo if you have to remove either for some reason.
May 2, 2010 #5 M maxcom Member Joined Jun 7, 2008 Messages 363 I found the box with the bolts and heat shield template that came with the THDP ........another senior moment :redface: Thanks all!
May 2, 2010 #6 M maxcom Member Joined Jun 7, 2008 Messages 363 brian said: Tom, PM sent Brian Click to expand... back atcha Brian
