Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
SignUp Now!Especially the last oneThou Shalt not ask what oil to run
Thou Shalt not be afraid to get your hands dirty
Thou Shalt not ask a question and get all butthurt when it’s not the answer you “wanted”
Thou Shalt not run E3 plugs
Thou Shalt not make a pass with less than 1/2 a tank of fuel
Thou Shalt not be a cheap ass and expect results
Thou Shalt not be afraid to verify ignition timing
Thou Shalt not run a Spectre air filter
Thou Shalt not take longer than 15 minutes to change out plugs
Thou Shalt not ever get caught “not ready” on the street
Thou shalt not be a scam artist buying or selling parts on this board.
Thou shalt not run old gas when in boost.
Thou Shalt not be offended if someone has never seen or heard of a "Grand National"
Thou Shalt not take for granted where your boost is set at
Thou Shalt not fear replacing the head gaskets, it is only a task
Thou Shalt not use your rear tire condition as an excuse
Thou Shalt not have fear of maxxing out thy combo
Thou Shalt not live on a 25-27 psi principle, turn it up
Thou Shalt not drip a drop of gas on thy perfectly crafted Spoolfool filler
Thou Shalt not skimp on vacuum lines and connections
Thou Shalt not violate the holiness of a TR with an LS swap
My favorite. What makes these cars special is what we can get out of an old tech 6.
Thou who violates this commandment will burn in the deepest depth of hell for all eternity while their balls are repeatedly kicked by everyone of their x-girlfriends and brake-clean is sprayed into their eyes while they are forced to look for the bolt that fell into the hole on the top of the engine cradle frame crossover.Amen!!!
That first one needs a stone of its own, imo!!
LMAOThou who violates this commandment will burn in the deepest depth of hell for all eternity while their balls are repeatedly kicked by everyone of their x-girlfriends and brake-clean is sprayed into their eyes while they are forced to look for the bolt that fell into the hole on the top of the engine cradle frame crossover.
These are funny and have a lot of truth to them.
When I had the engine out, I put peel-and-stick aluminum tape over that bitch before I painted everything black.That friggin hole in the cradle bit me before. Sucks!
