Kyle, nice to hear from you. This is Joseph, just in case you where wondering. I guess now that you mention it, I did know that you built your motor for the TTA. I didn't know that you got another GN. It's been awhile. Last time we spoke though, you didn't have the TTA running yet, so of course, I don't know how it runs. But I gotta get by there soon.
By the way Kyle what was up with the insurance thing. Did you forget that you had installed the Kenwood, or were you trying to do me a favor by telling her I had the more valuable stock radio. Anyhow, I had put the stock stereo back in by the time the adjuster came out, So in the end she ended up telling me that I was a liar and my car was never broken into, because you told her stock and that is what was in there. I left you a message to talk about it, but you never called back.
(sorry everyone, it is an inside thing, by the way, Kyle is the former owner of my car.)
I think it is an oil pressure problem because when I start the car I have close to 65psi at idle and after a few minutes of warming up, it drops to about 25psi. And the pressure goes up with the rpm range like it should while it is sitting still in park. That is all ok right. But as the car gets warm, the oil pressure drops after just a little while of driving to under 10psi! But the oil pressure will still rise with the rpm range, while at idle sitting still. But what has me really worried is while driving, if I floor it, the pressure actually drops 3-4psi until I get out of boost. Then it rises just over the already low pressure. I would be lucky to get close to 10psi pressure per 100rpm right after an oil change after diving the car for 15min. To top it off, after my turbo started to make an obvious whine noise instead of whistle, (don't get me wrong the car does still run, I just don't think it is a good idea to drive) the other day I got a pretty bad lifter tap, which I fixed that problem along time ago and haven't had a problem in over a year.
I could be wrong I guess--so if anyone has an idea, let me know.
I still want as much info as possible on engine builders, so that I can make the most educated choice as possible.
