turbo/downpipe leak?
dfirefighter
I already have a high BLM problem. I noticed that when i started the car, some condensation leak through the THDP and turbo meet. just below the knob of wastegate actuator. So a few questions. 1. can this be some or all aof my BLM problems? 2. I remember when I installed the THDP, that there was not a gasket of any sort. when I call quad air they said one was not needed. Do I need one? or do I need to retighten? thanks for any info:)
Quick answer to your question is no, it wont affect the BLM's. The leak you're refering to is post turbo so it doesn't affect any air going into the system like a header leak or other vacuum leak would.
Vacuum leaks, and pre turbo exhaust leaks will cause a high blm.
