What parts are you looking for ? , I have a couple extra turbos , exhaust manifolds , crossover , two intakes , I think I have a up pipe some where. I have the orginal HEI distribitor(weights are welded) & ESC . I Think I have 2 carbs some place also. a couple carb base plates.
I don't have every thing , But If you need something I just listed . email me at "fc227@mindspring.com"
The problem (If any) witha NA engine is the crank and pistons. The crank doesn't have rolled fillets on the rod jourals. and the pistons are not has Beefy , But you should be able to run 8# of boost without Major problems.
