hey all, hope someone has some suggestions....i've had car for awhile but still consider myself inexperienced. Car has been smoking ALOT (white smoke) when at idle and when i decelerate, smoke comes out both pipes. And it's enough to cover an entire intersection and it doesn't stop until i am driving consistently (probably still smoking but dissipates fast since i'm moving).
Now i just had the car idling in my driveway last night and now I see a puddle of oil under the engine. I pop the hood and there is oil dripping from the bottom of the turbo. I can see a ring of oil around the exhaust side of the turbo where it connects to the DP. There is a little play in the compressor wheel.
I am in central fl, do you think the turbo can be rebuilt? and if so, is there anyone in the area that is reputable and cheap? Any help would be greatly appreciated.
