Turbo oil drain hose
Night_train01
I am hoping someone can tell me what fitting is on the metal corrugated oil drain hose from the bottom of the turbo? I am hoping the connection to the motor is a -10 AN fitting. Can anyone confirm this?
It's NPT pipe threads, I think 1/2".
There should be adapters that would work with -10AN.
its not AN
at block there is a 1/2 npt x inv flare female adapter to the drain hose which has invert flare male at end
Thanks for the reply, I will be removing the original metal hose, install a 1/2 NPT into the block and then install a SS hose assembly.
