NorCalTurbos
Slowing down to SPEED UP!!!
- Nov 9, 2013
Is this a sign of a bad turbo? Or do I have a pcv issue/ breather tube/crankcase pressure causing a little Oil to seep through the turbo at the exhaust elbow housing. I have a bad exhaust leak at the crossover pipe and I'm getting white smoke out the tail pipes at idle not sure if the exhaust leak has the ecm adding so much fuel I'm getting the smoke but if I hit the throttle the smoke becomes unbearable in my garage. Could this be oil getting in the dp?Thanks in advance for any help
