i have oil leaking from the bolt pictured from what I can tell it's tight but it's next to impossible to get a wrench on it. Do the threads require sealant or is this a bigger issue, what's the best way to got at it ?
View attachment 305853 i have oil leaking from the bolt pictured from what I can tell it's tight but it's next to impossible to get a wrench on it. Do the threads require sealant or is this a bigger issue, what's the best way to got at it ?
I had the same leak location on my drain. If you haven't done this already. I used a sealant on both sides of the gasket and bolt threads. That was 4 years ago no leaks.
