TexasT
Texas, Where are you from
- Sep 10, 2002
So I'm having an oil leak that im chasing. It looks like it is the oil return from the bottom of the turbo. Do these stock corrogated pipes crack? It looks like it has one that has developed as about three flutes down it is dry then oil coats it below that. I didn't know if this is a crack or the turbo heat that burns the oil off. Thanks for your input.
Next question, is a stock tube a good replacement or do I need the cool guy braided piece? Tia
