turbo question
gnandy
my 87 gn has a t62-1, it has a t62 using the stock turbo exhaust housing..what type type of converter would you guys rec....
I'm running a te-62, not sure if they're the same turbo or not. I've got a 3200 stall in mine. It will not turn the tires over from a dead stop. I'd go higher than 3200 if the turbo's are the same. HTH.
I have a TA-62 worked just fine with a 3200 stall Protorque 10.5" converter single disk lockup. :smile:
Vigilante is a nice converter also got one in the other car. :cool:
