turbo ratio
michael evans
I am new to the turbo world coming from Procharged and have many questions.
Is there a chart (or guide) of what injectors go with a turbo mm size ?
i.e. If I have a 63mm turbo I should use X size injectors.
The mass flow you are supporting is what matters. BSFC around .6lbs per hour per hp. 600hp would require approx 360lbs/hr so six 60lb/hr injectors would be at or close to 100%.
If I can figure the theoretical air flow of the engine. I can then find the injector size ?
