turbo rebuild
87TIGN
Death by boost
So my turbo definitly is bad. I took it out and there is oil all on the intake compressor housing. I need to rebuild it but I thought it was a TA-49 as it turns out I checked the numbers on the housing and they are Garrett 25526630 and 466748-4 with the code QJ1921P on the bottom of the tag when I checked these numbers they turned out to be a stock unit am I correct? If so where can I get a rebuild kit? Are they a pretty straight forward rebuild?
-Andrew
i cant help you out on the #'s but if your going to get it rebuilt you best off sending it out to Precsion turbo or Limited.
