Originally posted by wiked87gn
i was told that wether you blow your engine or not this engines run really dirty and eventually will whippe out your turbo, this will extend the life of it by filtering the crapp that the other filter misses..
Originally posted by CARTMAN
Who told you that, the person you bought it off? I hope my 160k mile turbo doesn't read this thread![]()
this is how i did it, pretty clean if i may add and it looks nice...![]()
Originally posted by TurboJim
If that STP filter has a bypass you just removed your piece of mind. Use the Wix 51047 which has no bypass. I am sure there are ither filters too, thats just the one I used based on info at WIx's site.
Originally posted by Quick6'n'-K.C.
I think Jim was thinking anti drain back for the filter![]()
BW [/B]
No I was not and Wicked87, you're dead wrong....sorry.
Sorry, but the filter I use is a 51049, not 47, and right off their site:
Part Number: 51049
UPC Number: 765809510494
Principal Application: GM Family of Cars (59-67)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
And the commonly used FL1A equivalent:
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Go check out some filters before you stick yer foot in your mouth![]()
