turbo size
Originally posted by jadams
is the ta 61 a good turbo and will it fit
thanks guys
jason
yes,and yes.
you'll need some convertor.3000rpm would probably be fine.
i have a 3000 stall so it will work . ill try to get that one then. one more ? does it spool fast or slow
thanks
jason
spoolup has a lot more to do with combo than turbo size.if you have the right convertor for the size of the turbo and your fuel is not pig rich on the bottom you shouldn't have any problems spooling.
later,sean
