Turbo Tweak 6.1 Chip and 80lb. Flow Matched Injectors
10SECV6
Set of flow matched 80 pound injectors and a 6.1 Wideband chip from Turbo Tweak set up for methanol injection. These were used for approximately 3,000 miles and work great. They were also flowed at Richard Clark’s Garage to verify their consistency before install on a new motor. My car went 9.95 at 134 with these. The chip has the ability to read a Wideband and adjust fueling to your settings. Just recently removed from the car due to going to a bigger injector and aftermarket ECU. $250 shipped
I'm sorry, I didn't see it. I'll pass and let the next person buy them.
I have te 44 stock turbo and no mods to motor - my question is obviously can these work optimally or suggestions on upgrades?
Those on E85 with your TE44 stock motor setup have gone mid 11's .. at least for as long as the stock trans will allow ..
I've found that as soon as you step away from the stock turbo on E85 and can really let it eat .. you better have a built trans as they do not live very long ... mid 11 second power and traction do not work well with stock 200's
