Turbo tweak classic v5.7 chip question
dragrazor
What kind of realistic performance can I expect from a classic v5.7 turbo tweak chip on my stock 87 gn? I currently have a jet performance chip installed(came with the car when I bought it). Should I upgrade the fuel pump with the hotwire kit or is the chip designed to work with the stock fuel pump?
You should upgrade the fuel pump & install a "Hotwire" kit to feed the pump.
You will also need to increase your base fuel pressure with either a Bosch 237 fuel pressure requlator or an adjustable FPR.
I would swap the chip to a Turbo Tweek chip just to have the newest features available & to know exactly what you are dealing with.
Do you have a Scanmaster yet? If not... You should order one ASAP.
Good luck
~JM~
I have a scanmaster,I just wanted to know if i can keep my stock fuel pump and regulator for now or if i need to change it to avoid any engine damage and what kind of power/driveability improvements i should realistically see?
My goals are to have a reliable running/idling car with good performance. I am not going to build a race car. Fast farmer, do you know what hp you have with the upgrades in your sig?
No I don't. Haven't started the car since before Christmas. Waiting on parts and money. The chip and injectors were a gift from my wife. I should start the damn thing in about a week. Doing an F-body radiator conversion, deleting the oil cooler, and putting a trans cooler out in front.
Erics chip is the best money you'll ever spend on your car...and fuel and timing are completely adjustable. A new fuel pump and a hotwire kit are no brainers.
Ok, so what fuel pump do you recommend for my car? Stock everything with plans of upgrading to a tt chip, adjustable fuel regulator, maybe a better exhaust in the future.
I really like the Hotwire kit from Racetronix. http://www.racetronix.biz/customkititems.asp?kc=RFPK-006&eq= I went ahead & ordered a matching Walbro pump from them. This way I knew that I would be receiving a pump that had been inspected.
The adj FPR's will run you about $100, where the Bosch 237 will run you about $30 & it appears stock.
Exhaust in the future is the natural progression. Usually a 3" down-pipe from either TA Performance or RJC & then a free flowing exhaust from the cat back like Pypes or RJC.
~JM~
Anybody have a link to a bosch 237 fuel pressure regulator? I have been looking and cant find one. Also, thanks to all for your help. It is greatly appreciated. Without you and this site, I would really be lost(imagine that).
Sorry no links on where to buy a Bosch 237 FPR. I found mine at a local Import Automotive parts supply store that was a Bosch dealer.
Here is their web-site http://boschautoparts.com It looks like they have a dealer locater that will help you find someone near your home.
Good luck
~JM~
Even with the old Jet chip - you need a new fuel pump and regulator. Keep an eye on the For Sale/Trade forum, or post in PARTS WANTED.
I prefer Racetronix stuff for wiring kits, but fuel pump wiring kits aren't really high tech.
The 237 is non adjustable, and really expensive, $129.00. You can get a good used adjustable unit here.
http://www.rockauto.com/dbphp/x,catalog,23,partnum,0280160237,d,BOSCH_0280160237.html
I picked up a new 237 FPR for $30.
If your Jet Chip requires a higher base fuel pressure, you may want to check your current FPR to see what you have. Might find that someone has already replaced it.
~JM~
Pick up the fuel pump and hotwire kit from Racetronix...and you can grab the adjustable FP regulator from either Kirbans or RJC.
