Jon Early
 - Dec 4, 2014
Hello everybody,
I am looking for some recommendations on parts for my turbo L36 Camaro. So far, the engine is completely stock other than a 180 degree thermostat, EGR and EVAP delete, Autolite 605 plugs gapped to .055", a fuel pump hot wire, and about 2 psi of boost through a front mount intercooler (the lowest I can make my Precision PW40 go). I am not looking to make a racecar out of this. In fact I want to drive it daily. That being said, I was planning on buying a set of 42# injectors, Walbro 255, LS6 valve springs, and a tune from Intense.
Is there anything else I should look into? Being turbo and intercooled, am I speccing this out a bit short? I don't want to upgrade the T5 trans or tiny 10 bolt, so that comes into play as well. I am not completely against running E85, but I was hoping to stay away from upgrading the FPR and dealing with low availability in my area.
