65malibuss
- Dec 8, 2001
My previous best ET was a 13.642.
I ran some time trials at Englishtown yesterday and ran a 12.992 @ 101.99.
The only changes I made since last time are a Precision stock location intercooler and I launched with 10 lbs of boost instead of 5.
It took a few runs to figure out the tire pressure and get a good launch.
On one run I spun the drag radials for half a second at the start and ran a 13.520 at 101.94.
I eventually ended up with 24 lbs in the tires.
On a previous run I had a better mph of 103.06 but spun the drag radials at the start so the et was 13.246.
I'm still running pump gas with 17-18 psi boost.
My next mod will be to improve the cold air intake.
My air temperature sensor on the scanmaster is reading as high as 140 just cruising on the highway at 70 mph.
Then I will get gears, either 3.42 or 3.73, not sure which yet.
