why consider a different turbo and what reds thread are u talking about?Originally posted by 49-blues
consider a different turbo and read reds posts.
there have been alot of problems reported with the exhaust wheel...
Red Regal T s posts
Originally posted by newtowner
I am buying a pt51 , but wanted to make sure everything would bolt up. I currently have a te44 with a garrett turbine housing, Terry houston DP and an external waste gate. What changes will have to be made? if any at all.
I dont have enough injector or converter for the thing. If only I had more money to spend.Originally posted by NoNos38
I will sell you a Brand New PTE 63 that will push you into the 10's if your intrested.![]()
Matt
The te 44 needs rebuilding, and I found a good deal on the 51. With what it will cost me to rebuild it I will get out cheaper with 51. That is unless there is someone that can rebuild it cheaper.
The exhaust and compressor wheels need replacing, these 2 items + labor + plus the nornal rebuild parts. I called limit,pte,and turbonetics and they said the same thing "it will cost nearly what a new turbo would".Originally posted by The Radius Kid
So you're saying that you can buy this turbo for less than the $350 dollars that a guy like John Craig could rebuild your 44 for?
Again,I'll ask why?
