SignUp Now!What stall converter is suggested w/ this? Age/mileage?
You could get about 600fw with 55's unless you run really high base pressure or alky injection you can go a lot further. 22 psi will probably be around 80%dc unless you have heads and cam working together. I made 520whp@18psi and 600whp+@22psiIs 55lb injector enough to feed this to maybe 22 lbs ?
Seems it would be safe 528 HP at 80%
