Turbonetics 66BB S-trim for sale, low miles
WSLN 6
Powered by Murphy's Law
Turbo is like new, very few passes. Boost was mostly 18psi with only a couple of 24psi runs. Big external filter and synthetic since it was born. Bought new from Cotton's) F1 wheel, .85 exhaust. (T-36393).
$850
That thing is probably capable of some good 1/4 mile and hp numbers. Good luck with the sale. Thats a nice looking turbo.
It is fun for sure, take a look at Bison's times if you want to see what the turbo is capable of.
Yes I agree......:)
Al flanges are flat as glass, just bolt on and go!
9 sec power no problem. Not for stock bottom ended engines or light footed wimps unless you are going to run low boost which is also for sissies:tongue:
whatever you say sirpumpsalot:eek: i think this turbo would be ok at 23psi with stock bottom end right:confused: i like this turbo alot better then my 6776 turbo i bought
With heads and cam it would be ok at 23psi. Otherwise its the wrong turbo for the application imo. You need a really good converter and an aggressive tune to get the numbers out of it. I went 10.29@133.4mph with it a couple years ago. Boost was 28.5psi. Engine had decent heads and cam. It is much more effective on the GN1 headed engine i currently have. At 2psi less boost it is 6mph faster in the eighth.
i thought daves converter would be good for it?
Ok......
I will include shipping. :)
I'm really surprised it isnt sold yet! I would have bought it right away when you posted it up, but it is way to much for my stock bottom end motor lol.
GL with the sale free bump for you :cool:
It would spool ok but this turbo will make more power than the converter could ever couple with a hyd cammed combo. You will need to spend about $10k on an engine to have enough for this turbo to shine.
You might get 6 months out of your stock bottom end if you keep it out of detonation:biggrin:.
Car has been off the road for 2 years.... now its back on the road with a semi rebulid still using mostly stock parts.... Id like to enjoy it for a little bit before re doing the motor again :p
*thread hyjack*
Free bump for a great looking turbo i wish i could put to good use. I been dreamin about this thing since it went up.
