turbonetics bov block off plate
bought a pte fm that had a bov on the pipe. Guy wants to keep the bov. I don't have the money for a godzilla bov
Good welder in your area I'm sure would weld it shut for 15 bucks. If you want to eventually get the bov then a hunt for a plate you shall go on :D I'd say just don't run the IC til you can have someone fab up a new bov...godzillas are overpriced in my opinion when you can get a Tial for $150 less. Maybe even hunt for a good used bov like a greddy type S and have someone fab that up? Should be able to get that all done for under $100.
ok I'll check and see what options I have locally and go from there. I sent an email to precision to see if they can get block off plates
I would be contacting Turbonetics...or just make your own
Bryan
just get the vband ring and clamp from turbonetics or any other source (ebay) as is not a unique size , cut a piece of sheetmetal and slide it between the rings and put the clamp on
or cut the BOV pipe off , slide a 3" hose over it and two clamps
creative indeed!
we will just machine one up! find me the material and i will spin'ner on the lathe.
