turbonetics t-60
slimtastic
yea dude...I rock
ive got a turbonetics t-60 with a turbine mounted deltagate. specs as follows
p/trim
.81 a/r
t4,tangental housing,
ceramic coated,
v-band exhaust
polished compressor housing
4" inlet 2.5" outlet
deltagate body and valve ceramic coated as well
valve cut back for more flow
the center section has only about 1000 miles on it
im looking to get 750 cause i picked it up for 650 with neither the deltagate or the turbine housing coated. ive never ran it cause my combo dictates a bit larger.
this does not include shiping
pics here
http://www.houston-imports.com/forums/showthread.php?t=181235&highlight=T-60
Guess this was not a GN spec turbo, with a standard flange if would be a good deal for someone here
yea its not a gn three bolt setup. i know they make adapter flanges but those are kinda a joke. the best way to make this turbo work is to either mod the factory header and weld a t4 flange on or go buy a set(if they make them) with a built in t4 flange.
