This is WIERD.
A couple nights back, I had run the Buick for a bit, shut it off, then when I went to turn it back on, nothing. I turn the key, dash lights up, when I turn it forward to start it, the starter doesn't turn over.
Next morning, on my way out the door to work I turn the key in the Buick and it starts right up.
Today, I start it up, run it for a few minutes, then shut it off and change the plug wires. I go to start it up again, same thing happens, I turn the key and the starter doesn't engage.
So off the top of my head, things I think to check are the neutral safety switch, ignition switch, and the starter itself. Now I don't know where the starter motor is on this car, I couldn't spot it by looking around, and what I'd like to do is bypass the ignition (turn the car on, then kick over the starter manually) to see if the starter motor is ok. Then I'd move on to the 2 other things, I'll check Gnttype.org for wiring diagrams so I can see if theres a way to test the ignition switch, and last but not least, see if anybody knows where the neutral safety switch is.
Anybody got an idea? I remember someone referring to a 'no-start' diagnosis procedure by Turbojim, but I couldn't locate it...
Thanks,
Sam
Thanks,
Sam
