Hot Air Beast
Hot Air Lover
- Mar 10, 2007
It's taken me a year and half to get to this point and it is somewhat discouraging.
She looks so pretty but beauty is only skin deep when she won’t fire up.
Everything had to be brought up to readiness. It took about a dozens nudges to get the fuel rails primed. The bottom end had been coated with STP so spinning the engine brought up oil pressure in no time with no expected damage.
Ready for the real thing and she would not fire.
Checked spark – there was none. Crank timing had been set to 22 degrees after TDC. Cam timing test wouldn’t work ( voltage was supposed to drop off to nil at right setting but didn’t drop at all). This is the test called for by GM.
Tested the three way fuel rail connector and triggered spark – thus coil pac working.
After many hours in the heat we called it a night – will review manual and hope for a breakthru’
Anyone have any suggestions to point me in the right direction? I checked the fridge and it was plugged in.
