i`ve found that if you use the gas peddle to "set" the cable instead of the thumb on the throttle body method, you get the correct set the first time..otherwise, theres no accounting for deflection in the bracket....some more worn throttlebodys will go past( if even slightly) past wot, and some throttle cables wont reach wot...
