V VinPecora Guest Apr 19, 2002 #1 It there a specific setting for the cable?? How do I set it to the factory specs. What RPM should my trans be shifting at in each gear. Thanks guys!
U UNGN Can't Re- Member Joined May 24, 2001 Apr 19, 2002 #2 Push the "D" shaped button in and push the sleeve back. Open the throttle to WOT and it will adjust itself. Trans should shift between 4900-5100 or so
