TV cable adj/install
Just fixed a "humongus oil leak" for someone that had replaced the cable.. [At least the underside of the car won't rust anytime soon]..
Seems as tho the grommet was fubar and it was pushed into the tranny when the new cable was put on..DUH!! This required that the pan be taken off.
The cable is installed by:
Putting the new grommet into the trans.. Do NOT put it on the cable hsg. Add a smear of "sneaky cream" to the grommet ID.
Install the top end into the brkt.. Do not hook to TB yet.
Pull the cable slack down to the tranny end.. hook the "Z" into the cable and have someone pull up on the TB end. This will pull the "Z" hook and the end of the cable up into the hsg, thus preventing it from coming unhooked.
Slip the cable hsg end down into the tranny and install the lock screw. [10MM wrench, I think.]
Up top, hook up to the TB and then release the lock, push the cable hsg ALL the way toward the firewall.
W/ the floor mat OUT, press the throttle to the floor. The cable hsg will ratchet out.
Check for WOT and then check TPS settings.
If the cable is holding the throttle at < than WOT, move the cable hsg out a click or two. [I do this by opening the Tb by hand.] Reset the TPS if necessary.
Drive the car. Shift too hard? Move the cable out 1-2 clicks and try again. Too soft? Back it in a clik or two.
Back to huggin my T-400!!!
