Twilight Sentinel question
87gninpa
The twilight Sentinel in my car doesnt work and hasnt sicne i boight it this summer. i havent really been worried about it as the car needed other things that were more important. But now that everything is good with the car, im interested in fixing it. Now, what are some things i should look at or do in order to find the problem?> i really have no idea how the system works, so any info would be helpful, like are there any common solutions to it not working???
First of all you have to turn it on with the thumbwheel delay switch part on the dash.
Sentinel photocell must be up on the top panel exposed to the sunlight and not fallen down into the dash but that would turn the lights on all the time and they wouldn't shut off actually, but it's good to verify it is there and plugged in properly.
Secondly the amplifier often cooks and is located under the glove box area in a white box with one large connector with about 10 wires to it most larger gauge wiring.
Between the radio and the glove box.
Easiest access to it is to take the glove box out of the car.
