Blown&Injected
- May 31, 2001
1) the ASTG says the rear carrier assembly (4 small gears) should have .009 to .027" end play. My set has from .003 to .009. They feel fine, just not alot of play in them - Is this a failure?
And
2) Is the Clutch Apply Ring split like a snap ring? Mine has about a one inch gap that closes all the way until the ends touch when it is installed. The diagram in the ASTG has a dark spot at the 12 o'clock position and it is not clear if this is the gap.
Thank You All for the answers and help you have been providing!
And
