ok, do this.
connect a 2K (or 2.2K) resistor from input I5 to ground.
connect a 10K resistor in-line going from I5 to your brake pedal switch.
The resistors will cut down the voltage going to the PL input, since its really designed for 0-5v signals
Then you will be able to see the switch in PL
Bob
