stickybones
What?
- Dec 27, 2001
$25 + shipping. I used this UCA for ~2000 miles on the driver's side without any problems whatsoever. It works but I had to shim it more than I desired and I just didn't want two different arms on the left and right. I recently replaced it with the 14-0809-5R arm which only needed one shim to fit properly and was already installed on the passenger's side. This arm is perfect for someone who wants more positive camber for whatever reason. You can read up some on the UB Machine arms at this thread UB Machine UCAs This is an 8.5" arm with the balljoint socket offset 1.5". The more popular 14-0809-5R UCA is an 8" arm with 1.25" balljoint socket offset. If you need another one to have a set to do your front UCAs, they're still available direct from UB Machine as far as I know.
Mike
Mike
