Underboost
Mr. Dull
- Oct 4, 2005
Weenie X-ray won't get out of it's own way, but that is going to chang very shortly. Working on the game plan now.
And This Game Plan Is?????
SignUp Now!--------------------------------
You are correct, Mike, It's time to do some more on it. I am not going to settle for 300 puny horses. I am putting together a game plan now.
So what happen at fontoky, did you get to make a pass at the 1/4, what MPH and Numbers did you run?
Sucked! Track was like gum 10.50@127mph running out of gear 100ft before lights and a hot 93. Jeff also ran 4 tenths slower.
Making at least 700 H.P. what could be wrong with the cam? This is where people blow it. These production motors with small head ports are maxed at about 5800. Changing the gears is the most logical course. but the biggest obstacle hasn't anything to do with the car.I'ts trying to find a racer with both feet on the ground & some common sense. Going out to Fontana & beating the sh""t out of the car in 93 degree heat & not listening to your mechanic with 45 years of experience is a great example. Listening to idiots Is another.You didn't expect that with 3.73's? Cam's not big enuf huh? Go back to 3.42's or even better 3.27's and see the difference! I shift at 5,000 and go thru at 6400.![]()
Uh oh looks like someone is messing with your soup recipe.:biggrin:Making at least 700 H.P. what could be wrong with the cam? This is where people blow it. These production motors with small head ports are maxed at about 5800. Changing the gears is the most logical course. but the biggest obstacle hasn't anything to do with the car.I'ts trying to find a racer with both feet on the ground & some common sense. Going out to Fontana & beating the sh""t out of the car in 93 degree heat & not listening to your mechanic with 45 years of experience is a great example. Listening to idiots Is another.
------------------------------------And This Game Plan Is?????![]()
Well, for the motor I see a new TA-60 with the small .63 Garrett exhaust housing, alky, TT alky chip, & maybe Champion ported GN1 or GN1R ported, matching ported intake, maybe a small cam, & maybe T & D roller rockers.
I will continue looking for other improvements available for the suspension, & maybe discs on all 4 corners, & everything wrapped in a stock appearing body with factory paint.
Not arguing with your experience but if you're not going to rev it past 5800rpm why in the world would you put in lower gears?? If anything go taller gears and keep it in the torque range. If you guys are planning on sticking with the 3.73's then you answered your own question regarding the size of the cam..![]()
The gears are from the old setup. We found that on a dyno program that the car slows down with 342's. I'm thinking solid roller cam.
I have learned from experience once you find a cam that puts you in the ball park. the last thing you want to try is another. Because it drastically changes the set up & you get to start all over again. Gears & removing some weight should be the next consideration.Claims to need cruise control & AC to get to the donut shop. But the ultimate decision is Brent's I tend to be more cautious & take small steps.Right now he's going faster than I ever dreamed possible with what he has.He keeps telling me to let go of his ears, Cause he knows what he's doing.i'm willing to bet money it'd go faster...some of the TSM guys are even running 3.08's![]()
