78oldscutlass
Why am I here?
- May 2, 2002
OK, I have an issue concerning the 4th gear switch.
I did the modification of wiring the lock up solenoid where it only works in 4th gear (power comming in through the case connector, grounding through the 4th gear switch.
The converter will not lock up in 4th at all. But I locks up in 2nd and 3rd. I thought the switch is suppost to ground then pressure is applied to the 4th gear circuit or something? I bought a new one and its grounded all the time untill pressure is applied to the switch. So how does the switch actually work?
