Hi All,
We are taking the Fel Pro out of a buddys car who is retiring and outting it into another car. However when it was installed they drilled a hole in the firewall next to the GN main wire harness near the ECM.
We disconnected the sensor and tried to pull it back thru the hole but the other end of the O2 sensor is too big to get thru, leading me to believe they fed it thru, cut it and reattached (will take tape off the harness to confirm.
Is there a way to undo the wires of the O2 sensor connector without cutting it? We went to three Radio shacks to see if they had a tool to take it out, course they look at us like we had 3 heads.
Any suggestions or should we just cut it and reconnect?
Thanks for any and all help.
