Unknow Cam
oldwirehead
Army NCO on inactive duty
I got a cam in trade with some other stuff, and don't know what it is. Hope someone can help. :) Here are the etch numbers off the back of the cam;
268HER-2
R110
D5580-04
I just googled "268HER-2" and came up with Comp Cams High Energy Street roller (solid roller) 224@.050. There wasn't much information, maybe someone with some experience with this cam will chime in.
cam?
Measure one of the lobes to get lift specs, I'll compare it to mine while it still apart.
Sounds right. If you are not running high HP and high RPM with a BIG turbo, that cam is a bit too much for street use. 210/215 is about max for a 3.8 liter stock block set-up. Stroker or 4.1 stroker it will work great. 224 is a pretty big cam for under 252CID. (In my opinion)
