Hunter Dog
- Aug 1, 2015
We have an 86 GN. We have an unusual AC problem that to our knowledge has been present since we have owned the car since 2020.
We can run the AC for about 45 minutes and everything works fine with water coming out of the drain hole like it is supposed to.
But at this time is when the issues begin. The AC fan setting can be low or high and it can be on max, normal or bi level, none of these things appear to make any difference. At the 45 minute mark the water no longer runs out of the drain hole, not even at a slower pace. The plastic housing behind the glove box and above the feet of the passenger begins to have minor condensation in the entire area and then about five minutes later begins to have a drip at a similar pace to what it did from the drain hole. Within minutes the carpet is completely wet from this leak.
I can make this happen like clockwork. Does anyone have a clue what can be causing this and what can be done?
Thank you for your time in advance.
