**UPDATE- Buick Turbo V6 Grand National Performance Parts! Stage 2 Block, Champion Racing Heads, T&D’s, Harland Sharp, Accufab, Racetronix, RJC, GN1,
BUICKTIME
It's ah me, Mario!
TurboBuick.Com Supporter!
86/87 Buick Grand National, Turbo Regal, T Type & Turbo T Performance Parts: Turbo, Intercooler, Injectors, Standalone, Engine, Intake, plus more….
With 30+ years in the game and 3 cars I am finally cleaning out the garage so I can concentrate on one car to try and make BG this year after a 32 year absence. If part is not pictured I can post or send you the most recent pictures with the date.
Everything must go, it doesn’t mean i’m giving it away. I’m flexible and open to offers, but let’s be realistic (lowballers will be ignored and or BLOCKED!). PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask any questions you might have. Preferred Cash local pickup, especially for the bigger items. Local pickup is Oceanside (Long Island), NY 11572
I have so many parts that I had to split them into 2 posts (one Engine & SUSPENSION and the other is all Electrical Components). Keep an eye on this post as I keep it upto date and add more parts as I sell off some of these parts.
Wanted:
A) Chad Dickey Rear Seat Brace.
B) Clean Working Power Master.
SHIPPED= Price to the Lower 48.
(NEW)= Brand New
(BNIB)= Brand New In Box/Bag
(MOCKED)= New but previously bolted on but never used or ran
(Like New)= Slightly Used with approximately 1,500 miles
(USED)= Used
ENGINE/TURBO PARTS:
30) Stage 2 On Center 153 Virgin block with New Arp Main Cap stud kit (NEW)_$5,900
34) Champion Racing Heads Upper & Lower intake with billet fuel rail (Like New)_ $1,850 shipped
38) Comp Cams XR3 216/220 Hyd Roller Cam with Morel Lifters (Like New)- $600
**46) Champion Racing Billet Fuel Rails For Stock Intake Manifolds (Mocked)_$320
61) RJC 315 FMIC w/black coated pipes (has 3 holes on up pipe- for Alky and Vacuum) (Like New)_$800
63) HD Wastegate Solenoid for Stock style & TA housing (USED)- $85 shipped
**64) 3” Intake (MAF) pipe coated black w/12 inch cone filter (Like New)_$120
**65) Braided Turbo Oil Return line (Mocked)_$35 Shipped
**66) Melling K-20IHV High Volume oil pump kit (BNIB)_$45
**67) RJC Boost Controller (BNIB)_$55 Shipped
**68) RJC Racing PCV (BNIB)_$30 Shipped
**69) NOS Turbo Wastegate Vacuum Line Hose_$180 shipped
SUSPENSION/EXTERIOR PARTS:
81) Detroit Speed Rear Tubular Sway Bar Kit (1 ⅛”) Diameter (Like New)_$290
86) F Body Radiator in great condition (Like New)_$50
87) Rear Trunk Spoiler complete with both ends and OEM quarter End caps- (USED)_$900
88) OEM quarter End caps- (USED)_$45
89) Eastern Perf 3 inch High Performance Catalytic Converter- (New but has surface rust)_$350
91) Front Rotors Grooved with new bearings (Standard Lugs, NOT METRIC) (Mocked)_$150
ENGINE/TURBO SOLD PARTS:
SOLD……31) Champion Racing Heads Irons (B-Hive Pac 1218 Hyd. Roller) (Like New)……SOLD……
SOLD……32) T&D 1.55 Rockers for Iron Heads (Like New)……SOLD……
SOLD……33) Champion Racing Irons with Wire Lock, these were the original run of heads before they stamped them with the Champion CNC name. (they worked great and I never blew a headgasket, these need to be freshened up) All ports are the same exact measurements as the ones that are sold today (USED)- (includes 3 correct Fel Pro gaskets) ……SOLD……
SOLD……35) Champion Racing Heads IAC relocator (Angle Boss) (Like New)……SOLD……
SOLD……36) Champion Racing Heads Throttle Body Vacuum Block off plate (Like New)……SOLD…
SOLD……37) Precision Turbo PTE GEN 2 PT6266 DBB .85 A/R (Mocked)……SOLD……
SOLD……39) Comp Cams 206/206 Hyd Roller & Comp Cams Roller Lifters (NEW)- (lifters were put into a bucket of oil but never used or installed)……SOLD……
SOLD……40) TA Valve Cover (Like New)……SOLD……
SOLD……41) Harland Sharp Heavy-Duty Roller Rockers 1.60 (S60360K) (BNIB)……SOLD……
SOLD……42) Billet Aluminum T-Stat (Thermostat) Housing & Clamp combo (Like New)…SOLD……
SOLD……43) GN1 Throttle Body 72mm (no need for IAC relocator/angle boss)……SOLD……
SOLD……44) GN1 72mm Throttle Body Power 6 Plenum Only (Mocked)……SOLD……
SOLD……45) GN1 Billet CNC Throttle Body 1" Spacer Tapped for Vacuum……SOLD……
SOLD……47) GN1 KB3 SS Headers w/46mm Wastegate, Blow Off Tube & BC (Mocked)…SOLD…
SOLD……48) GN1 3" Down Pipe with a Flat Flange no Wastegate & w/Test Pipe (Mocked)…SOLD…
SOLD……51) Racetronix Fuel Pump Hotwire Harness (USED)……SOLD……
SOLD……52) Racetronix Fuel Injector Hotwire Harness (1 piece harness) (USED)……SOLD……
SOLD……49) Racetronix Teflon Fuel line Kit and Filter (-8 feed & -6 SS braided black conductive coating)_ need AN fittings at pump (Like New)…… SOLD……
SOLD……50) Racetronix Billet Fuel Psi. Regulator (BNIB)……SOLD……
SOLD……53) Accufab Fuel Pressure Regulator with 2x O-Rings (Mocked)……SOLD……
SOLD……54) Accufab 70MM Throttle Body (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……55) Precision plenum (bead blasted- Not Polished/flat) (BNIB)……SOLD……
SOLD……56) RJC A/D Power Plate for Precision plenum (BNIB)…… SOLD……
SOLD……57) RJC Drivers Valve Cover Breather (Mocked)…… SOLD……
SOLD……58) RJC Valve Cover Extensions (BNIB)……SOLD……
SOLD……59) RJC A/D Power Plate for Stock Plenum (Like New)……SOLD……
SOLD……60) 3" RJC DP w/test pipe (O2 Bung on the bottom, w/bung cap/plug)(Like New)…SOLD…
SOLD……62) BGC Stretched SLIC (has some cosmetic damage on the backside and air scoop, will need to be psi tested) (USED)_……SOLD……
SUSPENSION/EXTERIOR SOLD PARTS:
SOLD……80) UMI Performance Rear Non-Adjustable U&L Control Arm Kit 302116- (BNIB)…SOLD…
SOLD……82) HR PartsNstuff 3.8 Drivers side Motor Mount (Like New)_……SOLD……
SOLD……83) HR PartsNstuff Transmission Mount (Like New)_……SOLD……
SOLD……84) Wilwood D154 Front Caliper Kit (Like New)…… SOLD……
SOLD……85) Power Antenna-Universal (BNIB)……SOLD……
SOLD……90) Dennis Kirban Rear Seat X-Brace kit- (USED)……SOLD……
MORE PICS
