87 WE2
- Jun 28, 2002
D5 Converer
GM timing set (complete), low miles all teeth on gear, minimal were on tensioner
Fuel rail guage
IAC motor
Coolant temp sensor
Knock sensor
PCV
EGR cover
Turbo Oil feed
Turbo oil return
Turbo oil return brass nut
Vac Pod stock
Crank sensor
Cam sensor
Stock waste gate actuator
Oil cooler lines
Bare 86/87 throttlebody
Power steering pump with pulley
Good motor mount
Heavy duty IC hose (turbo to IC)
Stock fuel press reg
Stock injectors
Stock front cover, original GM untouched.
Stock GM water pump, very low miles
Trans cooler line shield bolts to pass side head
Trans inspection covers (2) bottom one has one mounting tab broken
Stock AC comp.
Fuel rail guage
IAC motor
Coolant temp sensor
Knock sensor
PCV
EGR cover
Turbo Oil feed
Turbo oil return
Vac Pod stock
Crank sensor
Cam sensor
Oil cooler lines
Good motor mount
Stock injectors
Stock AC comp.
