Turbo Keith
TURBO KEITH
- Sep 16, 2015
I just wonder why they are so high ? I just think they could be less expensive . Just my thoughts Keith
SignUp Now!I think they are relatively reasonable considering the limited market, made in USA, and the fact that they do have to actually make money on them. If you consider some OEM engine mounts with electronic NVH dampening that are $1k each these are a bargain [emoji23]
No trees were harmed in the sending of this message, however, a significant number of electrons were terribly inconvenienced.
I have done the HR motor mounts on my last two cars but don't think I'll use them anymore. I don't like the vibration they produce. I might try an RJC brace this time around
I was curious why you see them for sale constantly, I believe you just answered my question.
^^this
Considering the motor mounts for my TA block are $400, I would consider the $130 for stock mounts to be a pretty good deal....
On a side note, I do have a RJC frame brace for sale if you wanted to use that method to help prevent twisting.
Well SaidI don't like these mounts because they are unyielding and they stop the engine from rotating at the front of the engine. The transmission rotates in a counterclockwise direction in response to traction,so it causes the engine to rotate in that same direction at the back of the block. When we use a strap or a motor mount to limit/stop that rotation at the front of the block,we create a force on the block similar to wringing out a wash cloth. It makes much more sense to limit the rotation at the back of the block like a mid plate to reduce stress on the block. If we limit the rotation at the back of the block,it is equally important to use rubber motor mounts and trans mount to allow some movement to avoid breaking the trans case,usually in the area of the tail shaft.
