There is nothing shiny on the magnet. Fluid looks like slightly used trans fluid.Was there any sparkles in there? I've always used a hose clamp. When mine died & I pulled the pan it looked like anti seize.
there's barely anything on the magnet. disassembled the pump and it looks like a normal used pump. one side is like new and the other has barely detectable scratches, you can only barely feel them with your fingernail.Was there any sparkles in there? I've always used a hose clamp. When mine died & I pulled the pan it looked like anti seize.
car drives fine with connector unplugged. should i try a new solenoid? or is it an issue with the harness/computer locking the converter when its not supposed to?Trans is back in the new converter seems awesome. i think the TCC is locking at incorrect times, i am going to trying driving it with the connector unplugged to confirm. the connecter is very loose and weeps a bit too.
i forgot about mcmaster carr. I actually use them quite a bit for work, it never crossed my mind for this application though...
You do need the correct flaring tools to do a 37* but who doesn't love some new tools.
There are cheaper options but if you do much this thing works great for brake, fuel and of course trans lines
Bingo, most likely part of the problem all along...should i try a new solenoid?
The converter was staying locked I believe as a result of the TCC solenoid sticking which seems to be a documented issue with 200r4'sLet me try it again. Dose the convertor lock? Ill will quote you. "i think the TCC is locking at incorrect times"
When a lock up converter is used, it locks at whatever speed is programmed into the chip. This is usually in the range of 40-50 mph. It should unlock whenever one lets off the gas, or touches the brake. It also normally unlocks when one accelerates sharply, or, at wide open throttle. Some chips offer a programming option to input a specific mph at which the converter will lock even at wide open throttle. This usually picks up a little speed, but it is hard on the converter.
And sometime the problem that frequently occurs is that the converter does not lock when it is supposed to. Most often this is a problem with the electrical circuit that supplies power to the solenoid in the tranny.
I find it hard to put blame on the TCC. If told to lock and it doesn't or told to unlock and it dose not, Ill be rolling around on my back taking a ATF bath pulling the pan and replacing a TCC and 6 qt of oil at $5 buck a quart $28 pan gasket and filter.
